andiefrogger Posted January 12, 2006 Report Posted January 12, 2006 (edited) my right cylinder is a little leaner then the left ..... both cylinders have 165psi in them and i cant find any air leaks ..... not sure way??????? Edited January 12, 2006 by andiefrogger Quote
RNBRAD Posted January 12, 2006 Report Posted January 12, 2006 What brought you to this conclusion? Quote
andiefrogger Posted January 12, 2006 Author Report Posted January 12, 2006 the spark plug color ..... Quote
FIRST BANSHEE Posted January 13, 2006 Report Posted January 13, 2006 who did your porting, if the cylinders aren't flowing the same, the plugs won't look the same.check the resistance in your spark plug wires,if the left cylinder has higher resistance the right plug will look leaner. also check your base nuts , make sure they are tight. weak reeds on the left side will make the right side look leaner. hope I helped Quote
andiefrogger Posted January 13, 2006 Author Report Posted January 13, 2006 who did your porting, if the cylinders aren't flowing the same, the plugs won't look the same.check the resistance in your spark plug wires,if the left cylinder has higher resistance the right plug will look leaner.also check your base nuts , make sure they are tight. weak reeds on the left side will make the right side look leaner. hope I helped 458685[/snapback] i tryed everthing but the plug wires .... ill test the wires thanks man i did my port work ... guess i need to work on it more... lol!! Quote
Wallrat Posted January 13, 2006 Report Posted January 13, 2006 I'd say we just found the problem. If you weren't too aggressive on your porting you might be able to save your cylinders by taking them to a reputable builder. By reputable I mean somebody that has experience with porting banshees for a minimum of 15 years. Quote
andiefrogger Posted January 13, 2006 Author Report Posted January 13, 2006 ture but when i had my two 34mm.. the plugs looked great... nice color!!!! when i put the 39mm on it color changed in that one cylinder.. i dont know maybe its just me.... Quote
