I installed a set of PWK 28mm carbs, and I noticed the bottom of the left side carb hangs pretty low. There is a (for lack of a better word) nipple that is resting where the clutch cable hooks up.
Is this going to be a problem? If so what do you guys to to fix it.
Here is a crappy pic, but it should give an idea of what I'm talkin about.
Anyone run into this issue before? Any help would be great!
Yup, get a pair of reed spacers.
458365[/snapback]
this is one of the times that reed spacers do serve a purpose... you can usually pick up a set on ebay for less the $20.
458423[/snapback]
yep-thats what you'll need-i also have billet manifolds, and the spacers work just fine.
