its gonna depend on your elevation but i wouldnt recommend anything smaller than 21cc...pm dlnoss about it and im sure he will get you setup with the correct dome for your gas and elevation.
456775[/snapback]
Yep! dlnoss is great about responding both to posts and PM's. As loco said, it is going to depend on your elevation, but also other mods, ie. timing, porting etc. Generally I understand you don't want to exceed 150 psi cylinder pressure, without mixing some race fuel. However, if you have the timing advanced etc. it will likely be lower. Therefore, if you are at a higher elevation you can run a smaller dome (at elevation the air is less dense) at still have tolerable cylinder pressures. If you check this link,
NOSS Machine
it will give you a pretty decent approximation of estimated cylinder pressures depending on elevation.
These guys are right. Give me a call if you want. It will depend on your elevation and other mods. Usually 21cc if you are below 800' to 1000'.
