I notice in November when I last rode the shee it was hard to get started.
I had to put some heat on the motor from my topedo heater and then it finally started up.
Yesterday I tried to start it again because I wanted to go riding indoors and it is being a bear to start.
I don't think it is the compression, I don't think it is the rings
does anyone also have problems getting there shee started sometimes
In the summer the shee would fire up in three kicks
Should I run a different plug like a BR9ES?
later dudes and ladies
Make sure the choke tube between the carbs is in place and if that doesn't help then try turning your air screw in a full turn. If it is still difficult to start then put in 2 sizes bigger pilot jet for winter and this will cure your starting problems.
The problem you are having is when it is too cold the engine cannot get enough fuel to start the engine. So if pulling the choke out does not do the job then you have to find a way to get more fuel into the motor for cold startup.
I run a 68 pilot jet in My 35 A/S PWK carbs and my bike has been sitting for a couple of months and it started the 3rd kick no problems. Temp outside was in the low 30's.
453388[/snapback]
Right on! If you have had your carbs apart, will want to check and see if float bowls are on correct carb. They are numbered 1 and 2 inside the float bowl. 1 goes on the choke side carb. If these are swapped around the choke won't work propperly.
My shee is also hard to start. It is about 40 degrees here. I have a 280 main and 27.5 pilot. I had seen that loboboy has 68 pilots. Also what is the compression suppose to be for stock bore with 22cc cool head domes.
454031[/snapback]
He is running completely different carbs, pilots don't go that high in the stock Mikuni's which I'm sure is what your running based on the pilot and main sizes you quoted. I don't know that I would recommend jumping 2 pilot sizes all at once. You wont hurt anything, by doing this, but you probably only need to go one pilot size, and you won't possibly sacrifice throttle response.
454031[/snapback]
You are talking about totally different carbs man. If you put a 68 pilot in a mikuni it wouldn't run.
