I have a shee that has a drag port done to it and bored 30 over ,35mm air strykers,v-force reeds ,and a few other mods,I have a buddy who has a set of cpi out of frame big bore drag pipes . I was thinking of putting them on my small bore shee will I gain or lose power? Just checking to see if anybody has ever tried this before I try this . :bolt:
They'll work. You will obvoiusly need to jet a lot bigger, and you will lose any semblance of bottom end power. It will hit like a sonovabitch on top and be WAY loud.
If you're running a small bore shee, I would go with the small bore pipes. You will actually get better performance out of those than you will the big bore pipes. CPI's recommendation is not to run the big bore pipes on anything smaller than 440cc.
