JARE77 Posted December 27, 2005 Report Share Posted December 27, 2005 Its definetly an air leak some where. When you were washing it the water was geting in the intakes and cylinder area? The water was obiously getting in there from some place it shouldn't be. Id check all the gasket mating surfaces and check your intake and boots real well, and do a search on here for information about doing a leakdown test. Goodluck! Quote Link to comment Share on other sites More sharing options...
3ban5shee0 Posted December 28, 2005 Author Report Share Posted December 28, 2005 Its definetly an air leak some where. When you were washing it the water was geting in the intakes and cylinder area? The water was obiously getting in there from some place it shouldn't be. Id check all the gasket mating surfaces and check your intake and boots real well, and do a search on here for information about doing a leakdown test. Goodluck! 452327[/snapback] the water ran down the intake cuz i used a presure washer and have no airbox on the quad Quote Link to comment Share on other sites More sharing options...
mouse Posted December 29, 2005 Report Share Posted December 29, 2005 The motor had already died before it sucked all the water into it. We pulled the bike up on dry ground and tried to start it, but the kickstarter was locked up tight..thats when it was hydrolocked. 452106[/snapback] you can go get an air leak test done and find out if its leaking good luck Quote Link to comment Share on other sites More sharing options...
23champ Posted December 29, 2005 Report Share Posted December 29, 2005 you can go get an air leak test done and find out if its leaking good luck 452848[/snapback] Not me bro..my shits good!! Think ya got the wrong guy. Quote Link to comment Share on other sites More sharing options...
