kazaa187 Posted December 21, 2005 Report Posted December 21, 2005 how do u no wat jets to use with the mods u have done Quote
Handyman Posted December 22, 2005 Report Posted December 22, 2005 (edited) list all your mods that bike has... such as Carbs size type of exaust system mods done to motor elevation anything performance enhancing if it isn't stock list it Edited December 22, 2005 by Handyman Quote
kazaa187 Posted December 22, 2005 Author Report Posted December 22, 2005 its got 38mm keihn carbs boost bottle v force reeds toomey exaust im not sure bout the motor but i no its either ported an has a 370 or a 400 kit in it not to sure i jus bought it an the guy didnt no wat it had all he said is the guy he bought it off of had a big bore kit on it an the cylinders say ct on it an i looked an they do a 370 or 400 so thats y im assumin Quote
Banchetta Posted December 24, 2005 Report Posted December 24, 2005 Run the shee wide open in 6th gear for 5-10 seconds, shut it down, coast to a stop and check your plugs. That'll let you know how your mains are....Pilots and needles are mostly trial and error..try different clip positions on the needles and see which one pulls the hardest..As for the pilots, how well does it start? Quote
kazaa187 Posted December 27, 2005 Author Report Posted December 27, 2005 well its cold here rightnow so it takes a few kickes but once u start it it starts first kick Quote
2003LimitedBanshee Posted December 27, 2005 Report Posted December 27, 2005 Well one would assume (but we know what that means) that the previous owner should have had it jetted approximately correct, assuming (again?) that he was from the same area, ie. elevation, temp etc. It sounds like your pilot jetting (idle circuit) should be pretty close given the few kicks and then first kick startup after warm. If it seems to pull good through all rpm ranges chances are good that you're pretty close. As mentioned, do the WOT plug check and see what the plug color indicates. You are aiming for a light chocolate milk type color more or less. If you need to make adjustments to the midrange or WOT make the WOT first as it will affect your midrange. Once you have the WOT (main jet) adjusted make the appropriate needle adjustment to the midrange. Oh yeah, you can check out the pinned threads at the top for a full-on assault on this topic. Unfortunately, there is no cookie-cutter design, as every bike will respond slightly different. Quote
Banchetta Posted December 27, 2005 Report Posted December 27, 2005 03LB pretty much hit it on the nose. Pilot sounds pretty good, plug check and try raising the needles on clip to see how it feels, but do one thing at a time....adjust the air screws to throttle response and highest idle...I usually do this at an idle in neutral....(throttle response) Quote
