hello all, I have a 96 shee w/big bore kit and i want to swap it over to my 03 ice racer. I was just wondering if i have to change all the electrical too or anything else besides just the motor. I know all shees r the same but they changed some electrical around 96-97, but all i can see is that the cdi has one more wire on the 03 ,possibly a ground.
Any advice or tips &tricks would be appreciated,thanks :headbang:
ok that extra wire is an extra ground. i think it will all go together easily, also they use the same plug. i geuss if anything ill have to swap cdi and stator also. :bolt:
u sure that wire isnt for the brake light? i had a 2001 banshee that just had a light..was it in 2003 when they made it into a brake light?? just a thought..
449982[/snapback]
02' I think
