hi i live in australia so not shore on altatude etc. but i have some 35 keihin carbs which i just fitted and its a little to rich at idle has 155mains 35 pilot and needles on the top slot
mods to the bike are pro design head 20cc domes pro circuit pipes reed spacers 2 stage reeds plus 5 timming pro design inlet maifold bored to 370 any help would be excellent
Is it only rich at idle or is it too rich all the way around? If you're not ported, those 35's may be too much carb for your setup. :shrugani:
448830[/snapback]
Ditto. also why do you think its rich? Symptoms
448830[/snapback]
its only rich at idle and if you cruze at low speeds soon as it hits power band it goes well and its not rich i have check the plugs after a straight line thrash it could proberly go up a size
if i could drop the needle down one more slot if would fix it i beleve but it is already at the top slot and yes it is portted as well
I also believe it is a lot of carb for your setup.  Maybe if your cylinders are drag ported.
449629[/snapback]
sorry i fogot to mention it is portted i did run 320mains and 25 piolots with the standard carbs
449629[/snapback]
What kind of needles do you have? Carbs??
