docbones Posted December 7, 2005 Report Posted December 7, 2005 I just picked up my bike with a Trinity 421 powervalve (cheetah). What size jets do you run in powervalves? What is a good compression for all around duning? I prefer to use 100 octane gas. Also, I ate up an aluminum rear sprocket every 2-4 hours. Any recommendations on a good rear sprocket? Has anyone experienced this? What is good all around gearing for the dunes using 20" Sand stars? Thanks, Doc Quote
RNBRAD Posted December 7, 2005 Report Posted December 7, 2005 I just picked up my bike with a Trinity 421 powervalve (cheetah). What size jets do you run in powervalves? What is a good compression for all around duning? I prefer to use 100 octane gas. Also, I ate up an aluminum rear sprocket every 2-4 hours. Any recommendations on a good rear sprocket? Has anyone experienced this? What is good all around gearing for the dunes using 20" Sand stars?Thanks, Doc 445835[/snapback] Can't answer the jet ? but for 100 octane gas I'd run around 165/170 compression. Try the sidewinder tool steel or Timoly sprockets. They should last years. Stock gearing should be a good start with those size tires. Quote
sandslinger Posted December 7, 2005 Report Posted December 7, 2005 i have a 421 cheetah and run 38 pwk's for carbs and use a 145 main jet . i ride mostly at sand mtn., nv which is about 4000 ft. Quote
lonestar Posted December 8, 2005 Report Posted December 8, 2005 (edited) I just picked up my bike with a Trinity 421 powervalve (cheetah). Edited December 8, 2005 by lonestar Quote
