northshore Posted December 6, 2005 Report Posted December 6, 2005 2003 banshee, k&n pro flow with no box, fmf fatties with titanium 2 silencers, cool head with 19cc domes running 100 octane, 4 degree timing advance plate, and sea level 60-70 degrees. i just rebuilt my motor and added the cool head and timing plate, was running a 300 main with 27.5 pilot needle in the stock position. thanks for your help in advance. Quote
Ducman Posted December 6, 2005 Report Posted December 6, 2005 You should already be very close. Raising the compression is not supposed to change jetting but timing advance will. I would go up 1 main size maybe 2 to be safe. Quote
Banshee~ Posted December 7, 2005 Report Posted December 7, 2005 Do you just have the airbox lid off or did you take off the whole airbox? just lid off -320 mains whole airbox off-340 mains Quote
northshore Posted December 7, 2005 Author Report Posted December 7, 2005 (edited) I put the 320's in and it ran a little ritch, but i havnt installed the timing plate yet. it started on the 2nd kick, i ran it around the yard a little bit, but it wouldnt idle. i turned it off, and went to start it again and it would not start, gave it a little gas while i kicked it and it started up but again wouldnt idle. does this mean i need to increase the pilot jet? or just adjust the needle. i have the needle in the stock position right now, but i also just got a set of dyno jet needles that I need to install. any recomendations are much apreciated Edited December 7, 2005 by northshore Quote
