it's stolen Posted November 29, 2005 Report Share Posted November 29, 2005 I need some help with a starting point for jetting my 34 mm carbs. right now mods are t5 pipes, reeds, k&n air filter with the air box lid removed, +4 timing and a very milled stock head(17 cc). Elevation is between 4000 and 5000 feet and right now temp is too friggin cold, about 30 degrees during the day. I am going to have the cylinders ported (dune port), remove the air box and install clamp ons and switch to 34mm carbs.I dont know if it helps but here is a link to the carbs on fleabay carbs Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted November 29, 2005 Report Share Posted November 29, 2005 i'm at 3000 and ran 34mm keihin pj's with k&n pods, 175 pds compression, timing at +5 and used 38 pilots and 142 mains,air screws out 2 and a half turns and temp then was averaging 70 degrees.this may give you a starting point.i would probally go with 40 pilots and 145 mains air screws out 2 turns if i were you.keep check on your sparkplugs so that it is'nt burning to lean.hope this helps ya. Quote Link to comment Share on other sites More sharing options...
cbn70 Posted November 30, 2005 Report Share Posted November 30, 2005 What needles are you running in your 34's? Quote Link to comment Share on other sites More sharing options...
it's stolen Posted November 30, 2005 Author Report Share Posted November 30, 2005 What needles are you running in your 34's? 443086[/snapback] i'm not sure carbs are not in my hands yet Quote Link to comment Share on other sites More sharing options...
wayfst Posted November 30, 2005 Report Share Posted November 30, 2005 those are mikuni carbs. try up two steps on the pilot and about 350-370 on the mains. Quote Link to comment Share on other sites More sharing options...
Ducman Posted December 2, 2005 Report Share Posted December 2, 2005 If you bought Mikuni TM34mm carbs, I didn't look at the e-bay add, but thats what I'm running. See my motor settup in the sig. You need to run about a 30 -35 pilot (I run #35, different style pilot jet than stock), you need to install about a P-8 needle jet orafice, some refer to it as the dump tube (thats what I'm running) and I run a 310 main (uses same mains as stock banshee carbs). The 310 main size I use isn't over rich at all, right on the money when I got it dynoed with the A/F sniffer. You'd probably be fine at around 310 + or - snce your at a high elev. You can order the needle jet orafice from Sudco.com, there about $15 ea. When I bought my carbs new they came with a Q-2 orafice which was way to rich. I run the same needle that came with the carbs. I have the stock TM34 needle # written down at home if you need the # to verify yours is the same. Quote Link to comment Share on other sites More sharing options...
it's stolen Posted December 7, 2005 Author Report Share Posted December 7, 2005 If you bought Mikuni TM34mm carbs, I didn't look at the e-bay add, but thats what I'm running. See my motor settup in the sig. You need to run about a 30 -35 pilot (I run #35, different style pilot jet than stock), you need to install about a P-8 needle jet orafice, some refer to it as the dump tube (thats what I'm running) and I run a 310 main (uses same mains as stock banshee carbs). The 310 main size I use isn't over rich at all, right on the money when I got it dynoed with the A/F sniffer. You'd probably be fine at around 310 + or - snce your at a high elev. You can order the needle jet orafice from Sudco.com, there about $15 ea. When I bought my carbs new they came with a Q-2 orafice which was way to rich. I run the same needle that came with the carbs. I have the stock TM34 needle # written down at home if you need the # to verify yours is the same. 444164[/snapback] ok I took my carbs apart and the needle has 6DH7 stamped on it. the needle jet orafice has P8 stamped on it. I dont have a screwdriver small enough to get the pilot jet out at work. does this needle number sound right? Quote Link to comment Share on other sites More sharing options...
