Would heated hand grips work on a banshee? the kind you see on ebay, it says they work for snowmobiles too. would it be possible to unplug the headlights and wire the grips into the headlight switch? i am just curious cuz in the winter my hands always freeze
hmm, im not electrical wizard but i think the grips would have to have the same kinda pull from the motor that the lights do. justintoxicated and wallrat both have a pretty good knowledge of the banshee electrical system as they both have wired up some aftermarket lighting i do believe. if theydonr respond here send them a pm.
perhaps run a few 9 volt battery's to power them with a switch mounted on your controls? Just change the batterys out before a ride so they don't die halfway and you get cold. It's a thaught, but I am far from an electrical guy.
If anyone can find a way to set up a set of these and still use the lights let me know!!! I do a lot of night time snow riding in the streets.
I haven't looked at the heaters you specifically are talking about but my guess would be that they won't run on an AC electrical system which is what the shee has. To convert to DC you'll need to float the ground on your stator (easily done) and then install a new regulator/rectifier to replace the voltage regulator (about $30). After that its just a matter of installing a small battery and you're good to go. I would suggest getting the RS 200w stator tho since its way easier to float the ground on (or you can order it this way) and then you'd have no issues running your lights and heaters. As an added bonus, you could turn on the heaters before you even start the bike.
