i cant get my jetting right..
i have the biggest main you can get almost..
and my top end plug chop is still white...
my climate is just to cold for a 2into 1 intake..
its probly good in the summer...
i think im just going to buy another 35mm pwk for the winter..
cuz i want to drive it but its just to lean here..
i have an eek needle.. and its on the 4th clip.. if i put it on the 5th its just going to bog all through mid..
i hate my climate..
(230main)
has anyone else had any problems???
the bike still runs great.. but lean is lean..
thanks devin
do you have an air leak??
spray some carb cleaner around the carbs,intakes, reeeds. if it revs up something is wrong.
Devin where you at? Here in wisconsin, I'm running 190 right now and have no problem.
wesw, I'm really having a problem getting past your posts with those girls constantly shake'n about. :drool:
im in nova scotia , canada.. above maine...
i dont know what it is.. i have new crank seals on a hotrod...
i checked for leaks 3 times...
i used propane witch is sapost to work better for a leak down..
i checked the carb floats.. their fine..
it starts/runs fine.. pulls fine at wot.. plugs are black besides the very bottom..
peace devin
sounds like it super rich by your own words.
well..
i was hoping for it to be rich so then i could jet down...
but when i did the plug chop it was white..
and you can see the white ring in the plugs i rode home with..
it defently felt rich at first when i started driving it then it cleared up.. and screamed...
im just trying to make sure.. i had my motor apart 3 times because of my jetting..
and if its to lean id rather it sit till its wormer then to blow it up again..
think i should just drive it?????
peace devin
If your plugs are white with that size main, I have to agree with the others that you must have a leak somewhere. Never used propane, I've always used carb cleaner since I always have some around for cleaning. I'd check at flywheel side, the head and reed cage areas again. Check both cold and hot.
my plugs are black besides the last 2mm of the bottom part of the plug..
its white..
i dont know what it is.. i will check for air leaks again...
i just want to drive the danm thing..
peace devin
