if I remove the airbox lid. should I install some 220 mains instead of stock 200's? Also can my airfilter pop off with the lid off? 1000 ft elevation thanks
Edited by floyd398
dumb question, I guess :confused: . I thought from what people were saying about a big increase in air intake that it would make you lean out a bit. I'll just stay with stock jetting and check my plugs
Throw that stock air filter assembly away and get a pro flow kit with a K&N or UNI aftermarket air filter, pronto. The stock air filter is crap.
Put the 240's in and check your plugs. You may need to go up to 250's. :cheers:
To answer your questions yes. You should definitely check your jetting because you will flow more air without the lid. You should also invest in a Proflow or similar setup, or eliminate the box all together if you don't ride in a lot of water. The stock filter does use the lid to help seal the filter to the front of the airbox, and I would not trust the seal with the lid, let alone without. :cheers:
I've got my lid on with quite a few big holes drilled through. I'm a bit scared of getting muck in there. :cheers: But on the other hand I ride a lot of mud and dust all the time. :confused:
