icecold_shee Posted November 12, 2005 Report Share Posted November 12, 2005 (edited) I have a 2000 banshee stock bore and stock port, t5's, v-force, 20cc, and +4 timing. I plan on sending my cylinders off to Passion in the next 2 wks for a hot duner port, as well as getting my crank trued and welded, i have never tore down a banshee motor so i am new at it. My question is, what should i expect and are there any tips to make the rebuild easier and cheaper? Should i get my crank trued and welded, or go with a wiseco hot rods crank, will i be able to do the rebuild myself. My dad is going to help and he has built a few small block chevys, but not 2-strokes. This will be the first time so any input will help. Thanks Edited November 12, 2005 by icecold_shee Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted November 12, 2005 Report Share Posted November 12, 2005 Pull the motor out of the frame. Get a clymers or hanes to help you with torque numbers and directions. It's really pretty simple. I would go ahead and replace your crank, get a 4 mil stroker and have Jim port your juggs for that and have domes made for it. Quote Link to comment Share on other sites More sharing options...
icecold_shee Posted November 12, 2005 Author Report Share Posted November 12, 2005 ive thought about going with a 4 mil crank, but i do a lot of trail ridin, didnt know if it would suit my ridin style, and would it work good with the t5's and stock carbs for now until i can upgrade to some 33's? Quote Link to comment Share on other sites More sharing options...
Banshee~ Posted November 12, 2005 Report Share Posted November 12, 2005 ive thought about going with a 4 mil crank, but i do a lot of trail ridin, didnt know if it would suit my ridin style, and would it work good with the t5's and stock carbs for now until i can upgrade to some 33's? 436173[/snapback] The 4mil crank will give you better bottem end, but why are you getting a dune port if you trail ride alot? Quote Link to comment Share on other sites More sharing options...
icecold_shee Posted November 12, 2005 Author Report Share Posted November 12, 2005 he said that it would help out on the bottom end and give me more top end and would work well with the t5's, and i do go to the dunes bout 3 or 4 times a yr, do you know of a port job that would better suit me? Quote Link to comment Share on other sites More sharing options...
iceman Posted November 12, 2005 Report Share Posted November 12, 2005 a trail port Quote Link to comment Share on other sites More sharing options...
icecold_shee Posted November 13, 2005 Author Report Share Posted November 13, 2005 what about the gorr woods port, will it still scream on hte top and would it work well with t5s? bout how much does the gorr port job run? Quote Link to comment Share on other sites More sharing options...
icecold_shee Posted November 13, 2005 Author Report Share Posted November 13, 2005 anybody else got any input? Quote Link to comment Share on other sites More sharing options...
RabidPitWeasle Posted November 16, 2005 Report Share Posted November 16, 2005 I just rebuilt my motor the other day, new crank w/Hotrods connecting rods and Wiesco pistions (std). Just about went for a powervalve but wasn't in the budget this year.One tool you'll need is a flywheel puller( to take on and off) and make sure you got your flywheel lined up w/ woodruff key when you reinstall. Most other tools are just your hand tools, others needed_ 1-1/4 socket and an air impact comes in handy, get the Hanes manual lots of info also covers the Warrior 350. Have fun Quote Link to comment Share on other sites More sharing options...
