blackandyellowshee Posted November 3, 2005 Report Posted November 3, 2005 My friend is getting some 30mm PWK's and is wondering if they will work with the stock manifolds? Thanks Quote
blackandyellowshee Posted November 3, 2005 Author Report Posted November 3, 2005 BUMP! come on people someone has got to know! Quote
wesw Posted November 3, 2005 Report Posted November 3, 2005 most likely not if they do fit they will stretch the boot out quite a bit. would be smarter to get one that fits the size of the carb so you dont rip it and get an air leak or something later down the line. Quote
FASTOYS Posted November 3, 2005 Report Posted November 3, 2005 28-30 mm pwks will fit stock boots fine! Need to look closely at the bottom of the boots and all around and check for cracks first though. 33mm on up require bigger intakes to fit correctly. Let me know if ya need em !! Quote
odaen Posted November 3, 2005 Report Posted November 3, 2005 28-30 mm pwks will fit stock boots fine! Need to look closely at the bottom of the boots and all around and check for cracks first though. 33mm on up require bigger intakes to fit correctly.Let me know if ya need em !! 432731[/snapback] what he said. I ran my 30's with the stock intakes. Quote
