My Compression right now is at 160 psi. I am running on pump gas, if I advance my timing 4 degrees do you think i will have detonation on pump gas? I really dont want to run race gas. Thanks!!
IMHO, yes. It seems to be the common thought among HQ'ers that advancing your timing 4 degrees for anything above 150psi is going to mean Race fuel..or atleast a mix of it, just my two cents
and by the way..if you do decide to advance it...it will knock your socks off :clap:
jus remember at that compression..you need more octane = money going :flush:
Lol good luck man..hope more hq members post, i may be wrong(but i doubt it)
430665[/snapback]
It would be cutting it real close. You would definitly want to make sure that your main jetting was a bit rich if you do go +4 on pump fuel. Also, you wouldn't want to run it WOT if the motor was running real hot as this can also contribute to detonation. If you do go +4 with 160 psi you'd be plenty safe if you added 1 gallon of 110 octane to every 4 gallons of 91 octane pump fuel, resulting in 95 octane mix.
