yan Posted October 27, 2005 Report Share Posted October 27, 2005 (edited) my banshee is jetted for the summer do i have to rejette it for the winter if i dont and i go out in the snow when it is jetted for the summer will i mess up the motor or anything else is winter and summer jetting realy that important the winters are realy cold so do i have to jett it for the winter right now it is jetted for my pipes and summer riding do i rejette it for the winter what about performance rejetting for the winter will it slow me down what size of jettes should i use the jetts i would put in if i have to would be 10 bigger than what i have right if it is jetted for the winter what about summer riding will it kill the motor or somthing also right now i run 32 liters of gas for 1 liter of oil if i rejette it do i change my oil gas ratio Edited October 27, 2005 by yan Quote Link to comment Share on other sites More sharing options...
ellison445 Posted October 27, 2005 Report Share Posted October 27, 2005 You just asked the same question about 15 times Post up your mods and elevation and we will be more than happy to help you Quote Link to comment Share on other sites More sharing options...
eehsnab2 Posted October 27, 2005 Report Share Posted October 27, 2005 I had a buddy that jetted in the morning about dead nuts on... Later that night we went for a ride and said "man this thing is runnin killer". Well, it was but it was because he was dead on in the morining and when the temp. dropped down that night he was waaaayyyy too lean and ended up cooking his motor... In short... yes, you do need to fatten up your jets during winter especially if you are dead on/lean to begin with... Hell, I re-jet in the morining and at night now if there is a big change in the weather while on the coast. I think the rule of thumb is something like 1 jet size per every 5 degrees of weather change or something to that effect. Dont chance it... It only take about 5 mins to rejet. Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted October 28, 2005 Report Share Posted October 28, 2005 I believe the rule of thumb is 1 jet size for every 15-20 degrees. Quote Link to comment Share on other sites More sharing options...
slimeball Posted October 28, 2005 Report Share Posted October 28, 2005 Let me ask a question. I just bought my first banshee so I can ride the streets in NJ with my friends this year when it snows. My bike has been jetted for my fmf system and a few other mods. If I buy a jet kit can I change the settings on it or is it a one time deal? Can I save my old ones and put them back in next summer? What is the deal on Jetting as far as how many kits there are and and how much they cost because I have no idea. I need to learn this asap so I can do it myself? Does it realy only take minutes to change the jets? Quote Link to comment Share on other sites More sharing options...
eehsnab2 Posted October 28, 2005 Report Share Posted October 28, 2005 I believe the rule of thumb is 1 jet size for every 15-20 degrees. 430656[/snapback] That sounds about right... Get yourself a clymer's book... It'll walk you through the process on how to change your jets... Basically it involves removing your carb, carb bowls, and replacing a little brass nut looking thing which is the "jet"and then putting it all back together, simple as that. Don't bother buying "kits" just buy what you need from any bike shop and yes jets are re-useable. Quote Link to comment Share on other sites More sharing options...
