I currently have 22cc Big bore domes on a 4mm stroker...(Blaster pistons)........
will I get more HP by going to a 21cc or a 20cc dome?
If so How much?
Sea level elevation
34 PJs
Flat out Halz ASS!!!
do a dyno run before and after....You tell us!
If so How much?
Sea level elevation
34 PJs
424793[/snapback]
Polish, I should have some dyno sheets to post this very soon on this very topic. I have 3 sets of domes for my 4mm and I'm gonna do a dyno run at each of the compressions. Give me a few days to get it here.
I'm also gonna compare CPI/Shearers/T5's as well as stock/30pwk/35pwk carbs.
I've wanted to see dyno runs like this for some time now.
As soon as my builder gets some 10mm cubs from Calvin, I'll be rdy to go on this.
424962[/snapback]
thanks looking for the reply..........my bike was currently dynoed at 71 HP.....with 22cc domes......4mm....longrod.... blaster pistons.......T5s....34mm PJs
smaller domes..more HP????
let me know
i'm running a stock crank ,grr pipes ,35 airstrykers,k&n's,fastline ignition and a big reed conversion with a reworked stock head with 175 lbs compression and i'm putting out more horses than most 4 mil strokers.it was dynoed in 1997 when the work was done and it was putting out 75 hp and 48 ft lbs of torque on gas and 87 hp on alky.that was with 34pj's and t5 pipes and stock ignition.with very little work i could be closer to 90-95 hp rangeon gas.
