"S arm bearings" ? those may be a bitch
423125[/snapback]
Swingarm bearings can be a pain in the ass if the bearing is totally shot.
Meadows, Are you talking about the pivot bearings or the carrier bearings?
use a dremmel with a small stone on it. go indside the swing arm and dremmel thru 2 parts of the pivot bearing race. then the race will fall right out. be careful not to go in the swingarm steel housing though.
whats the difference. I pulled the swingarm bolt out to get to them, u tell me which they are. I got the old ones out but now im havein trouble gettin the bar to go through the bearing once i have it in teh swinger. How can i make this easier?? Thanks for the help. MEADOWS. <<<CWB>>> :dance:
put the new bearings in the freezer for a few hours. irght before u go to put them in heat up the area on the swinger with a propane torch..no settiline now. and they will pop right in like butter
