Might need to replace the inner and outer hub as well as a another new clutch! Give me a holler when you get it torn down and i will walk you through what to look for!
  • 2 weeks later...
Well got it torn down and yes i put oil back in it and gave it enough time to break in. With the plates in and the clutch put back together when you put it in gear and try to push it with the clutch lever pulled in it is hard to push it? Anyone have and idea? CLutch does not look fried and does not look to have any spots or warped.
did you happen to notice if your trans fluid is at all runny. if i were you i'd check the o ring for the water pump/clutch cover. it's what happened to me. the reason i smoked the clutch in the first place, actually. definately worth checking out.
bill
the point where the clutch cable connects to has an arrow on it. there is another arrow on top of the case. these two should line up when there is no pressure on the clutch. you will be able to move it by hand if you have slack in the cable. if it doesn't line up you need to pull the clutch cover off and adjust it with the bolt in the center of the clutch basket. if you need to adjust it then you just tip the bike on it's side so you don't need to change the tranny fluid. you still need to drain the coolant though. and uhhhh... do yourself a favor and buy a clymers.
later,
bill
