4-5 degress advancment for a mild to dune/recreational drag ported banshees and often guys will go up to a 7 +degree on more heavily modifed setups such as cheetah cubs and or bigbores ,strokers. the stock ignition timing is setup to spike at a lower rpm than what the motor is now capable of with higher port timing numbers and performance mods,so basicaly stock ignition timing is designed for a stock banshee with 25lb french horn pipes :cheers:
419210[/snapback]
Aftermarket ignitions...? $$$? well worth it?
Were you running +5 with the T5's without porting. I haven't had any port work done... YET. But I've got a ricky stator timing plate that should be here by Thursday. Trying to figure out if I will be making a difference advancing the timing now. Even if not, I can always set at 0 degrees until I get the porting done.
419210[/snapback]
Well said.. :cheers:
