hello im new on these. i change the pipe, air filter, main jet (280), and twis thortel control, i take all electric parts of the bike start on the frist kick and have the correct idle rmp stay on all the time, but when i give some gas i have the problem is like get to much gas and i tray to run and moves very slow like is rich on gas or like is the choke on, on the frist gear just move like 5 mph i just tuch the gas and go's up like a little bit but just a little bit then stay on the same rmp but whit to much gas, thanks for any advice!!!!! :(:cry:
Welcome to the HQ.
Are you having your problem at 1/4, 1/4-3/4, or at full throttle? It sounds like it's a jetting issue to me. Can you list your mods specifically example air filter: K&N Pipes: T5's... Are you running the stock carbs? Also where are you from?
Now that I re-read it do you have your Tors disconnected? It sounds like you tried to. Make sure the little black box that is under the left side of the fuel tank is disconnected.
Edited by PUSH THE THROTTLE
