wooten Posted September 19, 2005 Report Share Posted September 19, 2005 (edited) i can ride this thing for a short period of time or climbing hillsl and it spills out of the overflow tube onto the pipe is this a problem or does this usually happen on these ??????????? Edited September 19, 2005 by wooten Quote Link to comment Share on other sites More sharing options...
87sheerips Posted September 19, 2005 Report Share Posted September 19, 2005 Im in the same boat, shouldnt do this that quickly. You prolly blew your head gasket, check your impeller to see if it is moving with the kickstarter. If so, check out your head gasket. Quote Link to comment Share on other sites More sharing options...
Banshee~ Posted September 19, 2005 Report Share Posted September 19, 2005 What mods have you allready done? This is normal to a mildly moded shee, in hot conditions. Mine did it in 90+ degree weather and I added a nossmachine coolhead and engine ice and hasent came close to overheating again! noss machine webpage Quote Link to comment Share on other sites More sharing options...
scooter Posted September 20, 2005 Report Share Posted September 20, 2005 mine spits a little bit out the tube after a short ride in warm weather i think its normal too drip a little most lands on the plate betwwen the a arms a couple drops hit my pipes my coolant bottle is still full i have toomey t6s and delta v force3 reeds for mods engine is stock and runs great Quote Link to comment Share on other sites More sharing options...
wooten Posted September 20, 2005 Author Report Share Posted September 20, 2005 mine just has pipes and filter just rebuilt the motor the oil is fine no coolant in it where is the waterpump at on these things and how much do they usually run Quote Link to comment Share on other sites More sharing options...
chase@miamiatv.com Posted September 20, 2005 Report Share Posted September 20, 2005 4mm stroker + alota other shit porting etc......... and well my shit will overheat after i use the powerband for TOOO LONG lol ...... like wheni ran from the cops lol , try a bottle of watter wetter or something i heard its better ? or try aftermarket cooling head. both drop temps down 30 degrees i hear Quote Link to comment Share on other sites More sharing options...
Rooster Posted September 20, 2005 Report Share Posted September 20, 2005 (edited) Is it really hot, or are you just saying the fluid is spewing? Mine did that from day one (when the bike was stock) and continued doing that until I just lowered the fill level in the overflow bottle. It hasn't done it in years and the motor is also built now and I ride hard in Glamis heat all the time. Rooster Edited September 20, 2005 by Rooster Quote Link to comment Share on other sites More sharing options...
GREATDEAL Posted October 13, 2005 Report Share Posted October 13, 2005 http://kuoi.asui.uidaho.edu/~john/tips.html Check this out it may help you and give you some explanations to your problem. Quote Link to comment Share on other sites More sharing options...
fast500#12 Posted October 13, 2005 Report Share Posted October 13, 2005 check your impellar, mine was doing the same thing for a little while and then the top end let go. the blades melted off the stock impellar and caused the pistons to melt. Quote Link to comment Share on other sites More sharing options...
wooten Posted October 14, 2005 Author Report Share Posted October 14, 2005 where is the best place to get a after market impeller at Quote Link to comment Share on other sites More sharing options...
Johnny Dirt Posted October 14, 2005 Report Share Posted October 14, 2005 I have an 05 Banshee with 8 hours on it. I have also noticed some coolant drips at the overflow tube. Drips on exhaust pipe and a-arms. Only seems to do it after riding it for a while. Wont do it on short rides. Quote Link to comment Share on other sites More sharing options...
