Rodeoranger Posted September 19, 2005 Report Share Posted September 19, 2005 Well, I think my stator has craped out. At idle speed runs ok. When I give it gas one side has weak spark(right). The TORS has been removed for some time. Help me plz. Quote Link to comment Share on other sites More sharing options...
DIABLO BANSHEE Posted September 19, 2005 Report Share Posted September 19, 2005 check and sync.you carbs,check your plug caps and change your plugs see if that makes a difference i just had both plug caps fail and have the same problem.should be 5000 ohms or none resister cap should read 0:evil: Quote Link to comment Share on other sites More sharing options...
Rodeoranger Posted September 19, 2005 Author Report Share Posted September 19, 2005 I have a stage IV kit, new plugs, ect. I was wondering if any type of corrosion will damper performance of stator. I got water in that area. Cleaned it up real good but no fix... Quote Link to comment Share on other sites More sharing options...
