Ok I bought an 01 shee in a few pieces. I picked up the necessary parts to rebuild it from this site and ebay..and the dealer(rip-offs). Now when I try and start it, I get no spark. I tested the coil according to the haynes manual(it was confusing) and it failed so I bought a new one from the dealer. still no spark. So I got to thinkin about a ground wire issue. I remember, there are no ground wires that I can see. So, where are they? seems like I should probably make one or so to make sure Just wanna know where does it go. Like from where to where?
Also, if I put a voltmeter on the wires that go on the coil terminals, I get voltage whenever I kick it over. So I think that everything is basically eliminated except the ground. Thanks
