nick81
Everything posted by nick81
  1. bump...added a couple more things.
  2. nope, no TORS. I will take pics and send them tonight.
  3. Cleaning out the shed and ran across a few things. 1. Boost bottle $15 shipped 2. Stock carbs with throttle cable $40 shipped 3. rear shock. needs a new shaft $25 4. stock airbox with high flow plate. no lid $25 shipped. I will post more as im cleaning. Thats all for now.
  4. nick81
    needle clips
    Ace hardware has them. Like $.10 each
  5. Well it has had a jet kit installed, but i dont know the specifics. i just know that it ran pretty god about 9 months ago when the rod bearings went out. I am getting spark, all the time. I dont know if its a strong enough spark. i am going to check into that tomorrow. The choke tube, i made my own out of a vaccuum hose since i didnt get one when i got the quad. so that is in place. The fuel flows freely and is 105 Octane mixed. i got the fuel from a friend that ran it in his shee a few weeks ago so the mix is fine. I am going to follow the plug/jet guide i found to make sure i have the correct plugs, jets, heat range, and screws all set correctly. i will report back if that all doesnt work.
  6. Got a 01 shee in pieces a few months ago. Guy I got it from said that the crank needed to be replaced. So I rebuilt the entire engine. Mods that it had when I got it was pipes, reeds, jet kit, filter, 30 over bore, and some special idle screws. TORS and the ebrake were eliminated. Last weekend I finally got the thing running. Only problem was that the idle wasnt set yet. I had to put my thumb a lil on the throttle and it would stay running just fine. I ran it for about 5-10 min then my friend came over and we went to lunch. Came back and it hasnt ran since. I have taken the carbs apart twice to make sure they arent clogged. I have checked for spark. It starts only for a couple of seconds then dies SOMETIMES. I am so tired of this. I just want it to run so I can finally go play with it. There is a shop down the street, he says he will fix it for $60 an hour but i figure ive already spent so much time on it, that i would just like to finish it myself. any ideas?? It doenst start and half the time when it does fire, it back fires.
  7. Ok I bought an 01 shee in a few pieces. I picked up the necessary parts to rebuild it from this site and ebay..and the dealer(rip-offs). Now when I try and start it, I get no spark. I tested the coil according to the haynes manual(it was confusing) and it failed so I bought a new one from the dealer. still no spark. So I got to thinkin about a ground wire issue. I remember, there are no ground wires that I can see. So, where are they? seems like I should probably make one or so to make sure Just wanna know where does it go. Like from where to where? Also, if I put a voltmeter on the wires that go on the coil terminals, I get voltage whenever I kick it over. So I think that everything is basically eliminated except the ground. Thanks
  8. 90387-I 27G8-00 Shock Collar(4) the little bushings that go in the shock as a bushing or something. 90109-I 02A6-00 Lower Rear Shock Bolt 90185-I 0120-00 NUT,SELF-LOCKING (2) for the rear shock 2GU-14771-00-00 Muffler Stay(the little thing that the muffler mounts up to on the front of the quad. Clutch Lever- Stock or AM, doesnt matter as long as its complete. Coupling Collar for the exhaust. prefer the shiny AM ones.
  9. i got a spare layin around. its just stock. is the basket the thing that all of the clutch pieces slide into? the outer one? cuz i have one of those. I need some parts, just little stuff, pm me and we can maybe just trade.
  10. I think he was just offering his opinion as to how much it is worth. if you browse around on here, you see Banshee's with many more mods going for a lower price. I agree $2000 is too low of a price, but 5500 is way high.
  11. How about the rear shock? Are you selling that? if so how much? I am in tucson, aZ. zip 85705.
  12. Thanks for the info. What about registration or titles? I heard that titles didnt come with them until like 1993. also vin numbers. Can you tell the age of the engine or frame from them? I just got a banshee from my neighbor so this is all new to me. Also i ordered the haynes manual for the banshee. are they worth it? it hasnt come in yet and i havent paid for it so i was wondering if they were worth it.
  13. interested in the stock rear shock to 85705 tucson.
  14. What are the differences between the banshees through the years? My friend was lookin and the ads for used ones said something like a frame and b frame and such. what does that mean? Can you take a motor from 03 and put it in a frame from 92? also how can you tell the age from the frame/ engine serial numbers?
  15. 85705 tucson, az
  16. How about $500 shipped for the engine to AZ.
  17. I will take the keyswitch and cover...does it come with a key as well?
