I bought some 27.5 pilots from Tony Doukas this past week and noticed they are about a mm longer than the stock piltots on my stock carbs. I specifically told him i needed the 27.5 pilots for the stock carbs. Does anyone have a pic or know if they are suppose to be longer.
Jeff
stock is 25..next is 27.5 and on up...if the actual jet itself is longer then i wouldnt use it, id rather run what i know is right even tho the long one may work fine. does it have the jet size on the jet?? the jets should be the same length..
