stockridinshee Posted September 3, 2005 Report Posted September 3, 2005 my freind got a blaster the other day brand new and we went riding today. all it did was foul plugs, it fouled like 4 in 2 hours. then after each plug it wouldnt start, we had to push it. ounce it started it would run good until it fouled again. on the last plug when i took it out it was white not black the others and it was very hot and after that it wouldnt start and when it did it had no power at all, we let it cool and then tried again. is there a possibility he blew it up? i mean its brand new and i was watching him he rode it fine. no exessive reving or anything it shouldnt have gotten that hot. i dont have a compression tester but he has a warranty so they should give him a new one right?its also a holliday weekend so there not open. sorry about the novel i just wanna ride thanks for any help at all Quote
batoutofshell Posted September 3, 2005 Report Posted September 3, 2005 did you guys fill the oil tank Quote
Holyman Posted September 4, 2005 Report Posted September 4, 2005 did you guys fill the oil tank 411238[/snapback] Quote
Spitfire Posted September 4, 2005 Report Posted September 4, 2005 did you guys fill the oil tank 411238[/snapback] Quote
stockridinshee Posted September 4, 2005 Author Report Posted September 4, 2005 yes we filled the oil tank Quote
FASTOYS Posted September 4, 2005 Report Posted September 4, 2005 Usually on a new bike they will often mix the oil extra rich (throw some extra in the fuel tank) and that could be why you are fouling plugs . But the white color is throwing that idea out the window. hmmm. Does it run ok when running? When you take the fouled plug out it is white?? Sounds like it is lean to me on the jetting! Quote
stockridinshee Posted September 4, 2005 Author Report Posted September 4, 2005 at first when it was just fouling plugs it ran good but when the last one was white we put one more it and it was really hard to start and it was really hard to keep it running. it had no power at all. then i went over his house later that night when the motor had sat for a few hours and was cold. we tried one more plug, new gas and cleaned the air filter. it wouldnt even start by kicking it. how could the jetting be that far off from the factory? any other ideas? anyone? thanks for the help Quote
Banshee~ Posted September 4, 2005 Report Posted September 4, 2005 Usually on a new bike they will often mix the oil extra rich (throw some extra in the fuel tank) and that could be why you are fouling plugs . But the white color is throwing that idea out the window. hmmm. Does it run ok when running? When you take the fouled plug out it is white?? Sounds like it is lean to me on the jetting! 411330[/snapback] Blasters are oil injected. What kind of oil are you using....there is a special kind for oil injection. Quote
stockridinshee Posted September 4, 2005 Author Report Posted September 4, 2005 it was stock oil still he had prolly 2 to 3 hours on the bike total. Quote
Banshee~ Posted September 5, 2005 Report Posted September 5, 2005 Try what fast toys said, pour a little bit of fuel in there and shake the tank up. If that is the problem, then you can either rejet it or buy a oil injection block off plate. Then you will have to mix the oil and gas. You might call the dealer you bought it from and ask them if jetting might be the problem. Quote
