It is the right side that smokes. Your pulling trans oil in through the crank seal.
Also you could still be burning the old oil and carbon out of the smoking pipe.
gotta split them. the crank seal has a groove that fits in the case and clamps it down. you will get the old one out, but never get the new one in. 60 bucks for seals and gaskets and about 6-10 hours work and you will be good to go. dont forget to get yamabond sealer for the case halves.
411684[/snapback]
Thanxx man,But I found a good engine builder down here that would do the whole job for 100 bocks if I bring him the motor,seals,gaskets and all.
Edited by La 450 smoka
