:notworthy:
ok here is my latest problem
I installed my prodesign intake. got it all together and then started it up and it revved like mad man, had to shut it down couldnt get it to stop with the throttle only thing I could do is shut it off.
I looked over the Carbs and the slides looks good.
backed out the idle screws still no luck,
does any one think it could be that I need to go up on the pilot or the main.
I am thinking pilot because it has to do with idleing.
Currently 320's on 2nd clip
banghead
Any ideas PLEASE help
thanks keith
2003 Banshee
FMF Fatties
Vforce 2 with spacer
Pro design intake with boost bottle
Open air box with K&N
4 degree advance timing
pro design cool head 18cc
300 jets, middle clip postion on needle
LRD stage 3 port job
I am at 5500ft altitude
Edited by bansheecrazy
:cheers:
GODD LOOKIN OUT.
I found that the boots pushed into the bottle, they are a little dryrotted. I purchased them used. I went to lowes today and got new grommets to put on, I will try to get it together and start it but My job is sending me down to BATON ROUGE to help out with that disaster. I probley wont get to the bike for quite some time. Thanks allot all you guys are the best. I will let you know.
Thanks keith
  • 2 weeks later...
Well back ran it with 330 main jets in the middle, still a little bog thoughout the bottom half of throttle then Screams. It started out only in the first 1/4 then started to bog longer and longer. looked at the plugs they look good light brown maybe a little redish tint to them. I am starting to think topend with all this going on. It is at 40 over with 110 compression do you guys think I can get by with going 50 over no major scores just normal wear from what I remember when I had the jugs off. Or should I just go 60 over and be safe.
thanks for the help.
Keith
2003 Banshee
FMF Fatties
330 jets, middle clip postion on needle
Make sure your boost bottle isn't rubbing your pipes.The bottle doesn't help anyways,and a friend of mine actually burned his banshee up when one of his pipes actually rubbed a small crack in one side of his boost bottle(air leak).Just thought I'd let you know.
