If i advance my timing with the Ricky Stator plate +4 degrees and get a Noss Head with 20cc domes can i still run 93 octane gas? Or will i have to go higher octane?? My mods are below.....Thanks for the help. MEADOWS. :dance:
Pinging denotes low octane.. Do a compression test anything over 150 LBS needs to run higher than 93 octane.
FYI: I'm at 600 feet and 20cc domes and I'm at 175LBS
hope this helps
I'd probably increase the octane a little to be on the safe side. Maybe 10% to 20% race or av gas mixed with premium pump gas.
