Blackmon Posted August 29, 2005 Report Posted August 29, 2005 First off let me start out by saying that all I do with my banshee is drag race. My current mods are listed below. I am looking into getting an ignition with a launch rev limiter and/or reed cages. I have seen dynatek in rocky mountain and the v-force reed cages but I wasn't sure if these would be best for drag racing or if there were other brands out there that would be better. Any suggestions on which ones are better and which ones to avoid? Quote
race-a-holic Posted August 29, 2005 Report Posted August 29, 2005 GET IT PORTED!!!! This makes a HUGE difference.V-force reeds are good reeds and mine have lasted for a long time.The Dyna ignition is a good ignition also.Trust me,bolt-ons help alittle and porting makes a huge difference. Quote
Blackmon Posted August 29, 2005 Author Report Posted August 29, 2005 I have heard that if you port the motor with toomey t6 pipes you do more harm than you do good because they perform better with stock porting. I don't know if this is true or not but I have read it numerous times. Quote
Malott 1 Posted August 30, 2005 Report Posted August 30, 2005 (edited) If all you do is drag you should have it ported. Once you get it ported you will want to change pipes. The toomeys will sign off before the cpi's or shears will. It will be night and day difference with port job and a set of performance pipes. Edited August 30, 2005 by F.A.S.T 1 Quote
