bobbybonilla Posted August 16, 2005 Report Posted August 16, 2005 The upp slider pack I bought has 2 rollers with it, one is slightly bigger than the other. Which one is supposed to go on top? Which one should go on the bottom? Or does it even really matter? Just noticed tonight thtye were diff sizes, and the picture on the pack of the package doesnt say which one? Quote
racer Posted August 16, 2005 Report Posted August 16, 2005 just put them in place and then switch it around to se which looks right. Quote
bobbybonilla Posted August 17, 2005 Author Report Posted August 17, 2005 where'd you get that kit from? 405583[/snapback] I got them from BigBlue on the forums here. they also have them at http://www.inlandatv.com Quote
DUNEDEMON Posted August 17, 2005 Report Posted August 17, 2005 Big one on top, small one on the bottom. I think you can buy direct too http://www.uppracing.com plus they have a new "astro slide" swingarm roller / slide for the banshee. Quote
fast87 Posted August 17, 2005 Report Posted August 17, 2005 Actually the big roller goes on bottom and the small one on top, if you want proof check out their chain rollers section, the smaller 34mm one is top and the 39 or 42mm ones are bottom...linky- http://www.uppracing.com/index.php?cid=65, Also if anyone can't find a price the whole pack is 79.95 from UPP, here's the linky for that-http://www.uppracing.com/index.php?cid=69 Good luck and i'm gonna cut my cascade front slider like that and stick a wood screw through it because i can't get my swingarm pivot bolt out ~Mark~ Quote
