Holyman Posted August 11, 2005 Report Posted August 11, 2005 I just got some boyeson reeds and noticed that the bottom petal is solid all the way across and the upper reed sits on top of the lower reed. Wouldn't it flow better without the center bar? Anyway has anyone done it? Quote
pimpeinkc Posted August 11, 2005 Report Posted August 11, 2005 don't know, if you find out let me know Quote
rebelbanshee2 Posted August 12, 2005 Report Posted August 12, 2005 I bet the two smaller windows give more velocity/attomization than one larger window Quote
Master of Faster Posted August 12, 2005 Report Posted August 12, 2005 I bet the two smaller windows give more velocity/attomization than one larger window 404152[/snapback] I think that's the reason for the two-stage reed to begin with. Only the first stage opens for high-velocity airflow for good throttle response and the big pedals open at higher r's when more airflow is needed. Give it a shot, if it doesn't work out you can pick up a set of stock cages cheap and sell those to someone else who wants to experiment. Quote
Holyman Posted August 13, 2005 Author Report Posted August 13, 2005 I'm afraid that without the bar in the middle the back pressure will eventually crack the reeds. Quote
Master of Faster Posted August 13, 2005 Report Posted August 13, 2005 That's a good point, but with all the flexing the reeds are designed to do I would think it would be alright, they must be pretty tough. I have seen a set of cages with the center bars cut out, they were on ebay, they had solid one piece fiber reeds and were advertised as being drag ported. Quote
wayfst Posted August 13, 2005 Report Posted August 13, 2005 dude, you just got them and all ready going to cut them up yeah, the selling point was that the smaller petals would open on the low end and at high end the whole thing would open. seemed better than stock on the bottom, about the same on top. I would try it, stock cages a cheap and I don't think they will break ( about 300 pounds of nos through them ) if that didn't break them nothing will. see ya bud Quote
super88_banshee Posted August 13, 2005 Report Posted August 13, 2005 Could you cut out the + shape of metal in the back of the reed cage (the part facing away from the motor) I know you can port out each of the 4 smaller holes, but why not just make it 1 big hole? Thanks -TracY- Quote
