trex banshee Posted August 10, 2005 Author Report Posted August 10, 2005 i don't know what size pilot is in it. and it idles perfect the only reason why i don't think it is lean is because it has ran perfect up until sunday night. sunday morning we went to the quary ran good. every sunday night we drag race all our neighbors and freinds in front of our house. it was then it started to run like shit(bogging and backfiring..ect.) got the backfiring fixed but not the bogg. i will try cleaning the filter then go from there. Quote
pimpeinkc Posted August 11, 2005 Report Posted August 11, 2005 i live in k.c. and when i had the stock carbs on, i ran 320 mains and 35 pilots with toomies and no air box.... 280 or 290 sounds about right for the box on.. good luck Quote
BB3 Posted August 11, 2005 Report Posted August 11, 2005 Check you stator and pickup coil and the wires , mine was doing something like that and i cleaned up the pickup coil and sprayed it down with wd-40 and it took care of the problem hopefully this help's Later Quote
pimpeinkc Posted August 11, 2005 Report Posted August 11, 2005 Check you stator and pickup coil and the wires , mine was doing something like that and i cleaned up the pickup coil and sprayed it down with wd-40 and it took care of the problem hopefully this help's Later 403501[/snapback] good point there, sometimes it rusts in there and causes bad pick up ,,,,, Quote
trex banshee Posted August 11, 2005 Author Report Posted August 11, 2005 i will try that before we tear it down. we did a compression test on it and it only had 120 with i think 21cc domes. My neighbor just rebuilt his stock motor with stock head and it had 130. then we tested mine for the first time on my new guage it pulled 200psi i knew it was alot but not that much. Quote
Banshee~ Posted August 11, 2005 Report Posted August 11, 2005 Your running way lean. Im at 1000ft, sst's, K&N, and the lid off with 320 mains, 30 pilots, stock needle notch, and 2.5 turns out. Also, sst's like a fat pilot for some reason. Quote
trex banshee Posted August 12, 2005 Author Report Posted August 12, 2005 okay i will get some jets and try changing to what you said because i am 909 feet so pretty much the same. when we got the bike it had paul turner high revs on it.he didn't rejet it for the different pipes. could the bogging on the low end be it running out of gas? also where are the pilot jets located on the stock carbs? he can't seem to find them and i have never looked in a mikuni just keihen. Quote
bigboybanshee Posted August 12, 2005 Report Posted August 12, 2005 okay i will get some jets and try changing to what you said because i am 909 feet so pretty much the same. when we got the bike it had paul turner high revs on it.he didn't rejet it for the different pipes. could the bogging on the low end be it running out of gas? also where are the pilot jets located on the stock carbs? he can't seem to find them and i have never looked in a mikuni just keihen. 403805[/snapback] The bogging could definitely be it not having enough gas....I ran a 30 pilot with my T5's and shee loved it. In the stock Mikuni carbs you'll see the main jet as soon as you pull the carb bowl off. There should be a splash guard that sits underneath/around the main jet and this splash guard kind of disguises the pilot jet. Pull the plastic splash guard off and you'll see the pilot circuit right next to the main jet. All you need is a small standard slot screwdriver to get it out. Courtesy of BenBB.... Quote
trex banshee Posted August 12, 2005 Author Report Posted August 12, 2005 all right i will check it out first thing tomarrow. where is the stock needle clip position? Quote
bigboybanshee Posted August 12, 2005 Report Posted August 12, 2005 all right i will check it out first thing tomarrow. where is the stock needle clip position? 403870[/snapback] Stock should be in the middle but am not sure, I've never messed with a set of carbs that were completely stock. Quote
pimpeinkc Posted August 12, 2005 Report Posted August 12, 2005 sounds like your compession is low, i run 21cc domes and i got around 150 psi.... might need new rings? Quote
trex banshee Posted August 12, 2005 Author Report Posted August 12, 2005 yeh it does need to be reringed but it should run better than it does. i got the pilot out it is a 25 this is really lean isn't it and 270 mains needle was 1.5 turns out and i am not sure about the needle clip position yet. Quote
trex banshee Posted August 16, 2005 Author Report Posted August 16, 2005 okay the clip was in the middle position. i got some 320 mains and 27.5 pilots on the way, also should the little hole in the bottom of the slide be visible or not. In this diagram what does part no.13 do these are not in my brothers stock carbs! http://216.37.204.206/xtremepowersports/Ya...pe=13&A=178&B=1 thanks Quote
