aschultz91 Posted August 8, 2005 Report Posted August 8, 2005 I own a 1998 Banshee with .060 over, tors removal kit, toomey t-5s, adjustable timing plate, k&n clampons wiht outerwears, noss coolhead w/ 21cc domes, and a mild port job I live in Clinton, NJ with an elevation of about 400 feet and i usually ride at about 75-90 degree weather. What would you reccomend as my main jet, pilot, fuel/air screw, which clip... FYI im changin from a 2-1 pipe to the toomey's thanks in advance Quote
Banshee~ Posted August 8, 2005 Report Posted August 8, 2005 Try 350-360 main, 27.5 pilot, stock needle postition, and start with the air screws 1.5 turns out. That should be a good starting point for you. Quote
Dunsmoor86 Posted August 9, 2005 Report Posted August 9, 2005 that sounds really rich i would start with a 330main 27.5 piolet 3rd clip 1.5 turns out but just my 2c Quote
Banshee~ Posted August 9, 2005 Report Posted August 9, 2005 that sounds really rich i would start with a 330main 27.5 piolet 3rd clip 1.5 turns out but just my 2c 402653[/snapback] I wouldent put anything under a 350 main in there with port work and clamp ons. Quote
