I believe there are screws on the side and there are two prongs on the side near the front that clip into the airbox. After all that, it still takes a bit of wiggling and twisting.
Actually there are 2 bolts on the top at the rear of the air box. As Holyman said, after that you gotta wiggle that sucka out. Theres 2 pegs that you have to manuever around. Just push the box towards the carbs, It'll come out.
Take the lid off and take the two bolts at the back of the airbox out. Then losen the clamps from the back of the carbs. Take your radiator overflow tank off and I think you have to take your rear plastics off to do that. Now push the airbox toward the engine. There is a metal peice sticking out that the airbox has to clear before you can take it out.
