BklynBanshee Posted August 5, 2005 Report Posted August 5, 2005 Can i Put regular car coolant/ antifreeze in a banshee without posing a risk? Quote
RNBRAD Posted August 5, 2005 Report Posted August 5, 2005 Not a problem. I use the Prestone that is already mixed and ready to use. Quote
ke398 Posted August 5, 2005 Report Posted August 5, 2005 Yeah it works just fine with the green stuff, just make sure you use distilled water. Quote
hittintrees srh Posted August 5, 2005 Report Posted August 5, 2005 nope should'nt be a problem. Though you mite wanna think about adding "water wetter". it'll lower you coolent temp, and lub your coolant moving parts(i.e. your water pump impeller and others). Plus its just cheap insurance. A bottle of water wetter is only like $10 Quote
switchblade Posted August 5, 2005 Report Posted August 5, 2005 I run half a bottle of redline water wetter and water (zero antifreeze). It gives you the best cooling out of all the products out on the market. You just have to remeber to switch it out with antifreeze when winter comes. Quote
