my brother just got his first banshee last night. it runs pretty good once started but when it is cold it has to be pulled started every time. haven't comp. check yet but by feel kickstarter it has good comp. anyways after the first start it will start on first or second kick. all i know is it has paul turner pipes pro design cool head(don't know size of domes) with stock carbs and airbox. what size mains and pilots should it have.
does it help or not to use the choke when cold starting? Also, be sure to check the compression before you go messing with the carbs. You could screw with the jetting to find out that's not the problem, then have two problems.
