Right before the powerband hit it is crackling and bogging. But once it hits it is like it clears out. I have new gas and a recharged K&N so it's not either of those unless 91 octance and 20cc domes could be the problem. The VP place was closed so I went with straight pump gas. What do you guys think.
i don't know about the 91 gas with the domes, but the range that it's breaking up at sounds like you may need to lower your needles some. :confused:
what carbs your running
whats your jetting
meaning what clip, what main
whats your setup as in pipes, open filter box or what.
info needed
That transisiton uses the needle a lot. I'd lower that needle for sure. With it being so hot a lot of peoples jetting issues have been being to rich. Come winter it'll be, " my banshee just doesn't pull like it should",... lol. Jetting is affected greatly by weather changes.
Here is what I got:
2001 Banshee
Weseco Pro-Light Bored .20 over,LRD Adjustable Competition Exhaust, MX/Dune Port & Polish, Durablue X33 axle,Pro Design Cool Head w/ 20 cc domes,K&N Filter,AC Front Bumper,Nerf Bars,+4 timing key,Renthal Bars/Chain/Sprockets,Prodesign Kill Switch
Here is what I got:
2001 Banshee
394552[/snapback]
i take it stock carbs.
stock pilots, 4th clip on the needle, and 340 mains for the dunes it should be pretty good.
