i12gofast Posted July 16, 2005 Report Share Posted July 16, 2005 I got an 01 and the higher i climb in the rpms it begins to sputter, and feels like its loading up, then when I shift up, it takes off like a bat out of hell...until it gets up high in the rpms and does the same thing. Any ideas?? Quote Link to comment Share on other sites More sharing options...
Rare Scottish Tree Badger Posted July 16, 2005 Report Share Posted July 16, 2005 Have your air temperatures risen significantly? ... This could make you run rich on the main jets (and possibly the jet needles) due to less oxygen in the air. Higher altitudes and higher humidity will also reduce the oxygen content. Rare. Quote Link to comment Share on other sites More sharing options...
sredish Posted July 16, 2005 Report Share Posted July 16, 2005 Have your air temperatures risen significantly? ... This could make you run rich on the main jets (and possibly the jet needles) due to less oxygen in the air. Higher altitudes and higher humidity will also reduce the oxygen content. Rare. 393308[/snapback] Is this at full throttle, half throttle or what and when does this happen? Read the Troubleshooting your Jetting thread at the top of this forum and it'll give you a lot of info. Scott Quote Link to comment Share on other sites More sharing options...
i12gofast Posted July 18, 2005 Author Report Share Posted July 18, 2005 Its at full throttle, but i think since its more related to engine RPM wouldnt it be something with the reedvalves? Quote Link to comment Share on other sites More sharing options...
sredish Posted July 18, 2005 Report Share Posted July 18, 2005 Maybe, maybe not. That's why we suggest running a plug check in full throttle in 5th or 6th gear, which will provide the biggest load. Have you checked the plug after it sputters? When it starts sputtering, pull the clutch and kill it, keeping the throttle pinned, then read the plug. That'll tell you what's going on jetting-wise. If you think it maybe reed valve related then pull the carbs and inspect the reeds. Quote Link to comment Share on other sites More sharing options...
fast87 Posted July 18, 2005 Report Share Posted July 18, 2005 man.....you guys looked overt he obvious and probably the culprit of the WOT sputter...AIR FILTER!!!!!!!! clean it!! even if it looks clean, still clean it again!! ~Mark~ Quote Link to comment Share on other sites More sharing options...
