Trouble with the rockets? doesnt it say like on the main page of there web site, it fits RZ with no problems......?
I QUOTE!~ " One of the only pipes that will clear the powervalves on an RZ350 motor conversion"
Front page
Edited by 01bansheefox
What kind of problems are you having with the rockets? My RZ was just ported to run Rockets but with all this termoil going on with Rockets I can wait. Either way I also hear that the PTR's will work fine. Other than that I guess you have to dent the other brands of pipes.
Chris
All out frame pipes will work {of course} I heard the OLD OLD FmF's will work, Paul Turners will work Dynaport and Motofast 2:1's will work because they come out the right side. Otherwise you can put a small dent in the pipe to clear.
The pipes that have been mentioned above will all work great. PTRs don't have the RPM range to handle an RZ top end well. I used them for about a year, it will be the smoothest a Banshee will ever get. The Rockets work well and clear with no problems. Most pipes can be cut and turned to clear.
rzcolo has Toomey T-3s on his that have been cut to fit. I may have a set of Rockets for sale if I can find out if Shearers will fit.
