I always thought they were, and I'm getting ready to order a new set in a day or two , called alba , they told me they are different and will not interchangle, I can't see why this is the case, the stock lower a arms are identical and the yamaha front shock part number is the same for all years. Maybe I'm wrong but I don't understand why they won't work.
Thanks for the replies, yes I asked them about the shocks only, they told me it would be an additional 50-60 bux for shocks on a j arm set up. However , it seems they either misunderstood what I asked or trying to yank my chain. Going to order a set from them any way I guess.
I'm a little confused. Are you wondering if the arms are interchangable or the shocks? The upper arms are not interchangable, but the shocks are. I used the shocks off my 88' frame (j-arms) on my 2002 frame (a-arms).
It's obvious that the top arm's are not the same, but the forward upper mount is in the same place as any 90 thru 05 banshee. I do the j arm to a-arm conversion's all the time. If you look at a banshee with a-arm's you will notice all they did from the j arm chassis was add a tube and mount. Besides that everything is the same. B)
