Dont forget about were your going to set your initial camber and castor , so you can keep your balljoints in a nuetral position when the quad is at ride heigth. Also were the balljoint thread's into the upper arm. do not exceed 12 degrees from the plain of the arm itself, this is one of the most common mistakes made when people try to build a-arm's. I would not use heim's for the upper connection to the chassis [weak link] for castor adjustment instead ,shorten the pivot tube dimension, this way you can put spacers on either side swapping them from the front to the rear will change the amount of castor, all you have to do is figure out how thick you need to make them in relation to how many degrees you want it to move per spacer. One other thing , you should check the amount of steering akerman and the scrub patch, good luck and have fun.
