Just got back from a dune trip and my bike kept smokin clutches. They'd last about 3-4 hours, do a little draggin and all of a sudden the clutch would get real stiff, it wouldn't shift, then it wouldn't move. Install new clutch plates and repeat. After the first one went the bike didn't seem to pull at all like it was. The clutches were getting so hot it turned the 2nd, 3rd, and 4th steels blue each time the clutch went and the fibers melted. Musta been slippin horribly. Trashed both EBC and Tusk clutches, using 6 heavy duty springs. I'm sure it wasn't an adjustment problem. Only thing I can see is the basket is severly grooved and loose to the gear, you guys think this could've been causing the problem? Anything else I should be checking? I did check to see that the clutch arm was returning properly and the pushrod and ball weren't welded, no problems there. I was running plain ole 10w 30.
call jeff @ fast racing...1-785-364-5325...he carries the street bike clutch and baskets, pressure plate and hubs...good guy to work with and he can let you know what you need. me and my bro run this stuff on our 4mm strokers with no issies in the 6 months we been runnin it...
390929[/snapback]
Master of Faster, sounds like you have some worn clutch inner / outer hubs etc.. Like Loco said, feel free to give me a ring!! :cheers:
wayfst, it was those damn carbs your sold me!  <_<
lol
Jeff, I've got a new basket and inner hub here to try, if that doesn't solve my problem I'll get a hold of you for sure, thanks.  :cheers:
391383[/snapback]
Might want to check the outer hub also.
Ok , cool, let me know if you need anything!
