devshee14 Posted June 24, 2005 Report Posted June 24, 2005 hey im puttin an rz350 motor in my banshee but im cofused on a few things i have a few pics and can get more im wondering how does the power valves work i know theres part of it on the side of the cylinder but theres two threaded holes on top what goes in those holes?? also how do u rig up the clutch cable on the rz motor from the banshee ?? and from the carbs theres two cables that come out i know one is the throttle cable whats the other one?? Quote
broke Posted June 24, 2005 Report Posted June 24, 2005 hey im puttin an rz350 motor in my banshee but im cofused on a few things i have a few pics and can get more im wondering how does the power valves work i know theres part of it on the side of the cylinder but theres two threaded holes on top what goes in those holes?? also how do u rig up the clutch cable on the rz motor from the banshee ?? and from the carbs theres two cables that come out i know one is the throttle cable whats the other one?? 385364[/snapback] The powervalves are rotated by two cable which connect onthe other end to the powervalve servo. The servo is controlled by the PV controller which gets it's reading from the cdi, which monitors the stator to know what RPM to make them open. Simple, huh. The clutch rigs up the same on both motors. You kind of stumped me on the last one. There should be tow cables for the throttle. Quote
cbn70 Posted June 24, 2005 Report Posted June 24, 2005 There should be 2 cables going to the top of the carbs, and there is an extra one if you are using the throttle cable from the bike. It is for the oil injection pump. Quote
