Hi all:
Just learned if you slide or spin an aluminum wheel and rubber tire fast enough the debris shower can explode as it basically makes "rocket fuel". You pretty much need to keep going on a flat tire to produce this effect. (source: History channel Modern Marvels).
Interesting... sounds like a damn good reason to buy bead locks to me! :D
Sounds like something someone on here should have experienced by now? :shrugani:
-Bill
Edited by STLBILL
Hi all:
-Bill
384398[/snapback]
WTF?? :whoa:
Hi all:
-Bill
384398[/snapback]
Yep.
My uncle works at Thiokol (the people that make the rocket boosters for the Space Shuttle) and its a little more complicated but basically aluminum oxide and ground up rubber can make a great rocket.
Hi all:
384398[/snapback]
I saw that too!
I'm guessing that at the low amount we could produce it wouldn't be much of a problem. Not to mention you would need an ignition source. Also, how often do your wheel slip on the rim? I've only had that happen with under inflated tires when they were wet from water or snow (an ignition hinderance).
Your ignition source could be from the heat generated from the friction of the tire slipping on the rim...
384512[/snapback]
I would think if you were spinning enough to do that (again requiring some kind of lubrication or lack of grip between the tire and rim which would also cut down heat) you would probably stop, got off, and say 'What the f@ck! Why ain't I moving!'
I think I read somewhere that rubber and aluminum was the fuel used in that virgin atlantic space ship one. I think you would also need some compressed oxygen to get it to burn once it caught fire.
