Hey, I need 1 good reed petal for v-force 2 reeds. I bought a used set and when I got them, one of the petals is chipped. The rest of them seem tight with no chips so I really only need one petal, unless you have a set you'll sell cheap. Let me know and thanks in advance.
man your going thru the same bs as i am
just get a kit to replace the pedels.
i know passionre has a set, fastoys also might pm them about it
also put some loctite on the screws when you redo them
Yeah, I didn't want to spend a 100 bucks to replace both sides. I thought about replacing the one set but wasn't sure if it would make one cylinder run different than the other, having new reeds on one side and used ones that appear to be fine on the other.
